I just bought and put together a new computer from Newegg.
The set up went fine, installation of Windows 7 was fine, and installing the drivers for everything went fine.
Now when I am basically doing anything on the computer, I will randomly get a blue box that has an exclamation point (!) inside of a triangle that reads-
Warning!
+5 volts 4.494v
The second set of numbers is not always the same, but stays in the 4.4ish range (just popped up 4.473v this time).
This occurs fairly often.
I installed League of Legends onto my computer to give it a test run. The game loaded fine, but once I got in game it froze. I was still receiving the warning box message as I set up the game. After it froze, it stayed frozen (although I could still move my mouse cursor). Eventually, about a minute or so after, the computer 'crashed' went to a fuzzy screen for an instance and then restarted.
When it restarted, Windows 7 failed to launch.
This entire process has happened twice for sure, and possibly a third (technically the first time) when installing the game. I'm not sure as I had left the computer as it downloaded and installed.
I'm not sure if the motherboard, power supply, or some other piece of hardware is at fault, but I'm just guessing it was the motherboard.
I do not know what software is displaying this error message.
The computer has been running for about 4 hours and has crashed 3 times already.
I have already called for support from the power supply and motherboard companies, and neither helped or knew about this problem.
If it helps, this message has popped up well over 15 times while I typed this post.
Any help or input would be appreciated.
I have-
Asus M4A88T-V EVO/USB3 Motherboard
AMD Athlon II X4 Processor 3.0GHz 2.0MB cache AM3 socket w/ heat sink fan
Radeon HD 6670 Graphics card
4GB DDR3 Ram
Raidmax RX-730SS ATX Power Supply
Warning!
+5 volts 4.494v
I have-
4GB DDR3 Ram
