- Jul 24, 2012
- Upstate NY
Hey guys, it's been awhile. Hopefully some of you may be able to give some feedback about this.
I'm running a Thermaltake Water 2.0 Pro AWC, and was wondering what kind of temps you would expect if the chip is a 3570k running at 4.4GHz with 1.21V? Right now, when I run p95 with small FFTs, I peak just under 90C. I feel like something must be wrong...
I'm doing the same thing right now running completely stock 3.4GHz. Under full load it's going to 3.6GHz with my Sabertooth Z77 board. 1.08V. It's only been 5 minutes, and I've already peaked at 73C.
I've repasted this thing a few times already, and I'm giving up on the idea that it's not seated correctly. I've tightened it down as best as I could each time, just recently with a brand new backplate (these cheap backplates won't hold the grommets in place). It doesn't have any play in it when I try to move it afterwards, so it looks like it's down tight.
The pump is reporting 100% speed, too, per what the instructions require as well.
My ambients are around 25-28C regularly...but my idle temps are around 45C.
Should I try to RMA this whole unit? I've seen much better results when reading around.
Thanks!
Thanks!
