Hi All,
First post here. This is one of the best PC forums I've come across yet! I'm planning my first water cooled system and I need some advice on building the loop. I've read the stickies but would like to hear from you guys too.
I will be running the loop through my CPU, dual GPUs, RAM, MOBO, and dual 360 radiators. I have two designs in mind, one a dual loop and the other a single loop. While most would advice against a dual loop, I'm worried about the increased resistance/heat as this seems like a large loop. Would a better third option be a single loop with dual pumps? Would the second pump add an extra boost in a single loop using some kind of series/parallel scheme?
I'm currently leaning towards the Koolance RP-452X2 reservoir with dual PMP-450s.
http://koolance.com/rp-452x2-dual-5-25in-reservoir-for-1-2-pmp-450-s-pumps
http://koolance.com/pmp-450-pump-id-13mm-1-2in
