I'm building a new very high end computer and planning to get the deepcool genome case.
It comes with a prebuilt closed loop CPU water cooling, but not sure if i can expect high quality from a water cooling loop worth less than $300 including the price of the case. On newegg, a few people have commented that the loop was leaking after a while.
I would really prefer to use my own custom loop water cooling loop, with reliable pump/rad brands like XSPC, Swiftech or the like. At least i will be sure of the quality and i can properly leak test it. It would also allow me to use a water block without having two separate WC system with their own pump/rad, so less noise for me.
So now i'm trying to find a way to mod the case to use a custom WC, but i want to keep the same reservoir because the helix looks awesome and i love how it is built in front of the case.
I've googled it and found some interessing information here: http://mnpctech.com/deepcool-genome-gamerstorm-mid-tower-atx-gaming-case-review.html
So what kind of fittings and tubing would i need ? The black rubber tubing sucks, it's ugly and too small, i would prefer glowing "blood red" tubing or maybe just solid tubings, but i want to see through it.
Also, it looks like i will also have to change the radiator because i can't remove the tubing. So how can i know which replacement radiator would fit in ? I currently have a spare 360mm XSPC radiator but it may be too big to fit in. I don't mind about buying a new radiator, as long as i can confirm it will fit in !
Any thoughts ?
Thanks!
You can't remove the tubing on the radiator or water block, but the reservoir has G-1/4 threaded barbs, so you could swap it out. The 1/2" O.D. black rubber tubing would need to be cut. It's permanently attached to all of the barb connections in the loop.
Any thoughts ?
Thanks!
