Greywolf74
- Feb 4, 2018
Are WC fittings supposed to have a gasket between the fitting and the block or no? My monsoon fittings come with two gaskets per fitting but Im unsure if its an extra one or if it goes between the fitting and the water block. This is my first build, thanks in advance.
- - - Updated - - -
Sorry after re-reading what I just wrote my question might have been slightly unclear. I meant to say I know one gasket goes between the monsoon hardline pipe and the top of the fitting but I didnt know if the other one is an extra or if it goes under the base of the wtaer colling fitting. thanks
- - - Updated - - -
