- Jul 29, 2002
- Kingston, NY
All waterblocks are copper, you're thinking of the aluminum. You might add 10% antifreeze if you get the aluminum topped block to be safe. A scratch on the anodizing is all it takes to leave you open for galvanic corrosion between the copper of your waterblock and radiator and the aluminum of the top. The reason why I don't recommend the polycarbonate top is that over time the thermal cycling of turning your computer on, running it and then turning it off will make the top brittle and it may eventually crack. If you leave your computer on 24/7 or close to it, this isn't a concern.
If you put that hard drive up in one of the 5 1/4" bays (either just set it there or get an adapter or drive silencer for it) you should be able to put a dual heatercore in there. Measure first though. Should be at least 11" to fit.
