- Feb 27, 2012
- Ohio State
Right... obviously you'd be an idiot to force a 19tpi part into an 18tpi hole... what is the correct tap to use for that type of fitting?
mmm pvc seems kinda risky.... i guess it's fine for low pressure.Lol, long live the inch! Down with the metric system! I honestly dont recall if my tap was bspp or npt, ill see if I can find it and check. I only ever used it for threading pvc for a tube res so its entirely possible it was wrong and the pvc was just soft enough that it worked. ill dig out my box of seldom used tools in the next day or 3 and see which it was...
Wierd, how come they're using bspp? we're in 'Merica! They should use 'Merican pipe threads!
Hm, that's still strange. Just by doing a quick search, the fittings// taps// hw aren't any cheaper for bspp, in most cases parts are harder to come by and more expensive, (based on a topical search at mcmaster.com....)I want to say it had to do with the people developing older parts (Cathar's Storm blocks, Thermochill Rads) were not from the US. But that's kind of a long-shot.
Thermochill was based in the UK and if I'm not mistaken, Cathar lives in Australia. Hence the "British" standard of piping.
if your looking for a good rad, look for an oil cooler or a universal rad from a parts store, the fins aren't to close together and they also look nice. They run about 30$ or so and they would match up to the hoses used in the rest of the setup. There still aluminum so you would have to run antifreeze, but using a green fluid would look nice.
If you meant on what I posted above even in a closed loop using disparate metals the DI water would change characteristics over time. Was the only reason I was pointing that one out to begin with.I can see that since it's not a closed loop, and the chemicals are umm rather different than what PC's use in the liquid.
You need all sorts of special stuff.
Ethelyne glycol - and all other fluids on that list - have a lower specific heat capacity than water. Ethelyne glycol's specific heat is 2.36 kJ/kg°K or 0.56 btu/lb°F, meaning it takes just over half of the amount of heat to raise it one degree relative to water.
Of course you can't put freon in a water cooling loop, it would explode due to very high pressure. I mean like a freon compressor from a refrigerator then condensing rears in.
This is what I was talking about, these will fit 2 x 120mm fans. Hope to see pics when you start the build.
Umm, that's 2001 watercooling. You know much about flow rates and restrictions?
Show me one rig build log and pics that's from 2005 or later that has one of those rads in it that performs well.
