- Oct 14, 2012
Now that I caught your attention, I've been away from water cooling for about 2 years, currently have a H100 that I got on discount and has been decent for the month i've had it, but I want more cooling power.
I was searching frozen cpu and came across this lil kit
http://www.frozencpu.com/products/1...p_Included_w_Free_Dead-Water.html?id=4hjYEf5d
175 bucks for a whole kit, aside from the res with integrated pump, it looks very good.
Now for the question I need help with. I have an old Swiftech GTZ block, a MCP655 pump, and a mangled Swiftech Quiet Power 220 (may throw it away as it has so much dust and so many bent fins that I don't think it may be worth anything)
My original plan was to buy the 1155 adapter for the GTZ, a XSPC Res/pump combo compatible with my MCP655, a Swiftech extreme performance 220 slim rad, tubing, all with 3/8'' fittings, and a silver bullet to eliminate any growth.
The difference is only about 6 bucks between the 2 and I've read the XSPC block is excellent.
Which should I choose, about the only thing I don't like from the kit is the 7/16" tubbing and the res/pump combo, as everything else looks good to me... hut on the other hand, the MCP655 pump is better, I get red tubing, and the Swiftech rad is a bit better, but the block, being so old, may hold me back. That and my pump was manufactured in 07, so it's got some age too...
