So I am looking to do a custom waterloop on the EVGA 790i FTW motherboard. I need to cool the mosfet and the NB/SB because they get super hot when I try to overclock the CPU.
I found these from performance-pcs.com:
http://www.performance-pcs.com/ek-mosfet-790i-water-block.html
http://www.performance-pcs.com/ek-mosfet-790i-water-block-part-2.html
http://www.performance-pcs.com/bits...reezer-striker-extreme-nb-sb-water-block.html
A couple questions when I was planning out the build:
1) So these are the parts I need for the mosfet and the NB/SB, but I am not sure if i can mix these parts together because the black freezer extreme block seems to be a different material than the ek mosfet one.
2) If I am cooling the mosfet and NB along with the CPU and possibly 2 - 3 graphics cards, what would the ideal number of radiators and how strong should the pump be? Is two 240mm Radiators good enough for cooling everything?
Here is a picture of the motherboard:
