I recieved shipment of my Antec P180B Case, BIPIIGT Radiator, Storm Water Block, Acetal Maze4 GPU Block, D5 Pump, 3x Scythe S-Flex Ninja Fans, Window Kit with 120mm Fan Port Precut, Radgrilllz 2x120mm, DD Fillport Resevoir, and Tygon tubing. =) =) =), I am really excited to start this project this weekend but I already foresee problems. There is no where to mount the fillport resevoir to the top of the case because I decided to put the fans and rad mounted internally in the top 5.25'' drive bay. With that said is it possible to mount it horizontally... say on the side panel? I would leave extra tubing so it won't be taunt and come undone while removing. I realize I would have to turn the computer on its side to top it off but other than that would this be safe?
Thanks,
Mike
Thanks,
Mike
