- May 31, 2010
I've decided to jump head first into watercoolings and have been looking around at forums to see where i could get good solid input on my decision and i came across overclockers.com. So here's what i've decided on. Let me know your thoughts. Would much aprreciate it
Pump: Sidewinder Custom MCP655 / Laing D5 with G 1/4 Threads + x2 Bitspower 1/2 x 3/4 Shining Silver Compressions
Radiator: HW Labs Black Ice SR1 360 Carbon Black - Triple 120mm + x2 Bitspower 1/2 x 3/4 Compression, Swiftech MCR120-QP Quiet Power 120mm + x2 Bitspower 1/2 x 3/4 Compressions + Swiftech MCB-120 Rev 2 Radbox Radiator/fan housing
Reservoir: EK-Waterblocks EK-BAY SPIN Reservoir - Acetal + x2 EK High Flow Fittings G 1/4 to 1/2in. ID Barb
CPU Block: EK Waterblocks EK-Supreme HF Universal Socket - Acetal+Nickel
GPU block: EK Waterblocks Nickel Acetal waterblock for GeForce 480 GTX - EK-FC480 GTX
Fans: Scythe 120x25mm SlipStream SY1225SL12SH - 110 CFM x 8
Tubing: Feser Tube - FT - Active UV Hose - ID 1/2" - UV BLUE 5 feet
Coolant: Thermochill EC6 Non Conductive Coolant - Clear 1L + Petra'sTech PT_Nuke -PHN Concentrated Biocide (10mL)
Extra fittings: Bitspower Matt Black 1/2in. Compression Fittings for 3/4in x6
Misc: Logisys Dual Red 12 in. CCFL Light Kit
Total cost: US$666 + US$111 (shipping) = US$777
Config: Pump -> CPU block -> 120mm radiator -> GPU block -> 360mm radiator -> Reservoir -> Pump
Fans in push/pull config controlled using Scythe 4x fan controller
Casing is my existing Cosmos S
Aim is to get good cooling at minimal noise production with the option of max cooling with noise increase
Let me know if i'm missing any components or if you think anything could be improved
