- Dec 3, 2004
- VT... or MD
WC Build -- No longer budget.
OK, with the air cooling setup i picked out running me $90 i feel the need to consider other options.
Noise is not a concern of mine, there are ways to deal with that (ear plugs) Preformance is my goal here.
I have a good deal of tools... and would be making a seperate enclosure for the WC equipment. To the point that only the lines to and from the block, and the block itself are in the case. I am also willing to take the time and make the effort to save a bit here and there doing as much of the build as i can with home made parts.
Disclaimer: I have not done a WC setup before so forgive any newbish statements. But I'm willing to make the effort and learn.
Can I get a dual pump (or one realy big pump), dual rad setup done for under $150??
About the idea in my head:
Lots of head pressure
Home made PVC res
Heatercores in parallel
Would be going to CPU only
I think it would be cool to run a blower setup here... so im willing to write that off if it pushes me over budget. A blower like the one seen here.
Here are some other things i choose to ignore in the final cost. So that they wont contribute to going ober on the budget.
Hose clamps, barbs, soldering stuff (have), hose -- i found a source for free.(1/2in)
Now for a diagram of sorts...
Thanks, -- Steve
Home made PVC res
Code:
/<HC_One>\
|Res| ~~> |Pump_1|~~~~~~~~~~~~~~~~> -{ }- ~~> |CPU|
\<HC_Two>/
Thanks, -- Steve
