- Jul 17, 2013
Hey,
I finally got my ek backplate for my 290 DCU II.
The GPU is running for a few weeks now, watercooled with an EK full block.
Nice temps and quiet.
Today I installed the backplate, took the six screws and washers out, put the plate with the thermal pads on it on the GPU and fixed it with six new screws (no washers).
At first everything seemed fine. I mean, it's just a simple thing...
But I was greatly mistaken. As soon as I taxed the GPU with a game or benchmark the card made some sort of a buzzing sound. This is not your typical high pitch coil whine, but sounds rather like a loud cheap fan with a nasty motor rattle. It is really loud and annoying.
I let it run for quite some hours, hoping it would settle, but it didn't.
After checking a little more, I discovered that the sound came from the rear end of the card. The area where the thermal pad on the backplate is.
Loosening the screws a little and "pulling" the backplate up decreased the intensity and made it almost stop.
My guess is the coil whine the card would have made resonates through the TIM into the backplate, causing the whole thing to get amplified.
I googled this, but nobody seems to have this problem.
Any ideas?
How about running the backplate without thermal pads? Temps are fine as they are even without the plate. Or would the heat be trapped under the plate, causing the card to overheat?
Any ideas?
