Naixnaixnaix
- Apr 20, 2013
So I put together a new computer for the first time ever, and I'm having the weirdest on and off problems with it.
I installed everything in, got to bios and got a post beep. But sometimes my computer has the weirdest problems and I'm not sure why. I was able to run windows, all the fans are spinning, I even played some games for quite a while and ran prime95 and everything seems okay.
However there are some problems, sometimes the computer:
-Doesn't show a signal from the computer to the monitor, went away after restart but weird.
-Won't shut down
-Powers on by itself (only happened once)
-Makes weird noises, for example I was listening to music and suddenly I got this loud grinding/screeching noise for like 1 second and then it went away
So I'm not sure if there's even a problem, my ram checked out on memtest, but now I have no idea where to check, I think it might be a psu or grounding issue? I've been using it fine for 3 days now playing games and such without a problem or crash but it bothers me.
My build is:
i5 3570k
Radeon HD 7950
Asrock Extreme4
Seagate barracuda 7200 hard drive
Help?
-Won't shut down
My build is:
i5 3570k
Radeon HD 7950
Asrock Extreme4
Help?
