Hi Guys
New to water cooling, ive tried to do as much research as i could before posting this as to find the answers for myself but would like more input!
Im building a weird setup, using pc water cooling parts for a welding cooler application. The state of water coolers in the welding world is still in the stone age it seems and extremely overpriced. The quality and efficiency of the pc cooling parts is MUCH higher so im trying to build something revolutionary in a way.
So far im looking at using 2x480mm black ice rads
http://www.performance-pcs.com/radiators/black-ice-nemesis-l-series-480-stealth-radiator.html#
8xXSPC Pro Series 120mm Fan
http://www.performance-pcs.com/xspc-pro-series-120mm-fan-pwm-500-2000rpm-3-pack.html
1x Swiftech MCP655 pump with speed control
http://www.performance-pcs.com/pumps/swiftech-mcp655-pwm-12v-water-d5-pump-module-pwm-oem.html
Obviously, since im using it for a welding application, i wont have a cpu to control the fans so my main questions are related to fan speed control. Ideally i would like to have the fans sitting at a low rpm and or even off when the coolant is at say room temp and as soon as the controller senses the temp start to rise, to be able to turn the fans on and start controlling the temp. I was looking at using something like the NZXT Sentry 3
http://www.performance-pcs.com/fan-control/nzxt-sentry-3-touchscreen-fan-controller.html
to achieve this. What is the best way to run more fans off the controller? Also considering putting at least one or two fans as intake into the case. These will have filters on them as to keep shop dust out of the case. Noise isnt really a concern, as it will be in a welding shop.
The basic requirements i have is i need to be able to run 1L/MIN of coolant at a minimum of 30 psi and the comparable cooler cooles at a rate of 1,660 W
(5,660 Btu/hr.)
Im thinking of building at least a 8L resevoir (just because it seems that most welding coolers have a large capacity).
The only other thing im missing i believe is a power supply for the fans and controller.
I plan on running temp in and temp out gauges, pressure gauge and flow meter so that i can keep an eye on it all. Im also going to build an aluminum case to house it all, so that i can set my welding machine ontop of it.
Again, i know this is a very off sort of project but i greatly appreciate any input you guys have!
(5,660 Btu/hr.)
