- Mar 12, 2002
Personally I prefer a reservoir setup. They make bleeding much much easier and faster than bleeding a T line IMO. To bleed the system you fill it as much as you can and fire up the pump let it circulate until the res is nice and aerated then turn your pump off for a few seconds to let the bubbles out. Repeat this process until you need to top off the reservoir. Then just let it run for hours and hours and it will most of the way bleed itself. In a perfect world you should be able to get 99.5% of the air out of your system and seal it up then never have to worry about it. Im only about 2 days since my last teardown and rebuild on my FX system and it has very little air left in it. Probably in another few days I might finish topping off the res IF I feel like its gone down enough(more than 1/8 of the tank empty).
