It might not work, this is true……but I would give it a try. It works in Abit, Asus, and Soyo Kt133a boards so why not IWILL? I think the chances are very high that it will……IWILL!
I would bet on it.
The 14 multiplier will most likely go away, that is my experience. The KT7A has a 14 multiplier but when I put the TbredB in, it only went to 12.5. You had to do some bridge work to go higher.
One thing though, all the multipliers are screwed up. You have to try them all on the 100 bus to find the one you want. They are all rearranged. If I set it the 9 multiplier I would get 17. It would boot to 2260MHz. It ran fine at that speed with my fan set to high but it drove me crazy.
