- Jan 17, 2008
- Overland Park, KS
Take a look at this result:
http://forums.hardwarezone.com.sg/showpost.php?p=29596535&postcount=2
He is able to push E7200 to 3.4Ghz (upper limit) with default voltage only.
I don't know what cooler he uses (most likely not stock cooler).
Since that he doesn't need to increase voltage, I assume it's safe to push up to 3.4Ghz with stock cooler (+400mhz comparing with E21xx@3Ghz on stock cooling). Increase in speed alone should cause little heat.
1) I tend not to increase voltage because higher voltage would reduce the life of the CPU. How much voltage can I add without noticeably reduce the life of a CPU?
2) I don't know how much I can gain if I add an US$20-30 aftermarket cooler. Approximately how much further can I push and at what voltage? I want to play safe without stressing the CPU too much.
3) Approximately how long can an aftermarket cooler last? How much power do they consume?
4) What about getting a US$10-15 cooler?
When they say reduce the life, what they usually mean is it will last for 3 years instad of 5...unless you use extreme voltage.
In general, try to stay under 1.4V for the Duals.
