- Apr 26, 2009
- Athens, Georgia
Well Im back again, I thought that my system was 100% stable and had ran through a slew of tests (occt and prime 24 hours) and my system gave no errors or blue screens. I used the system for online gaming for about 4 days and one day while my son was playing around in crysis I got an error that crysis had ended. I did'nt change anything and waited a few more days to see if it was some software glitch and no problem for 4 more days until lo and behold COD4 had suddenly stopped for no apparent reason, I started playing again and played the rest of the night without issue. This was at 3636 mhz 1.45vcore, nb and 2222 1.325 nbvdd and ht at 2020 with 1.2 ht voltage. I decided out of curiosity to run prime and It failed about 4 hours into the test. I tried it again and this time it failed 1 hour in. It had previously tested fine and all of a sudden it was failing. I ended up lowering the overclock .5 on the multi and raising reference clock to 203 to yield 3552. This remained stable for about 14 hours of testing. Being on who does'nt like to accept defeat, I tried lowering HT to 1800 range. Still failed. Memory is at stock timings and was at max overclocked 14 mhz. So I decided maybe PSU was giving wierd spikes that would cause me these issues, I went and bought what I thought was a mack daddy power supply (and one of the few that jonnyguru.com had ever given a 10 on performance to)
The Antec Signature 850. Tried prime blend run again and failed the same. I ended up raising VCore to 1.475 (shows 1.472 in cpu-z) and have so far been stable prime blending at 3654 (203 * 18)...Question is if this proves to be long term stable.....Is it a safe voltage for 24/7 usage and not just for benchmarks. Max temps using coolermaster v8 at about 60% fan speed is about 48c
This is with door to room closed off and ac vent closed as to let room temp rise above normal to simulate worst case scenario.
Edit: after looking at coretemp log it has been up to 50c but room is really hot I am at verge of breaking a sweat using computer but cant really say what ambient temp just that it is almost hot in here after running prime 2.5 hours with room closed off.
