- Mar 24, 2012
So I got bit by the watercooling bug, and have decided to toss my all in one Corsair H70 and go for a modular setup, and I was wondering what the best radiator I can get INTO my DF-85 is. At the top there are 2 140mm fans and a good bit of space, so I figure if I use that I would still have the most workable room inside (as opposed to the 120mm fans on the back).
I would rather a 140x2 radiator so I can use larger fans at the top of the case without a shroud, but if there is a better 120mm fans option that would fit using a shroud, that also is an option.
I'm not looking for the budget option here, rather the best performance in my chosen footprint.
I have decided on using an MCP 655-B pump, the Raystorm full copper CPU block, an Aquagraphx GTX 680 GPU block (hopefully I can buy that next week).
I'm not finding any recent reviews on a 140x2 radiators, and even fewer on 140mm fans which provide good static pressure.
Also, does anyone have a specific recommendation for tubing, a reservoir, and what to use for coolant? I saw some which like bolt right onto the 655-B but I wasn't sure if they were better/worse than stand alone ones. And I don't even know where to begin on tubing/coolant.
Thanks!
Chris
Thanks!
Chris
