there are like 3 memory IC on the market ... all of them run at the same timings below 3000 and only Samsung B is in kits above 3600 ... there is not much to think of
list of what is probably Samsung B ... ~70%
https://www.morele.net/pamiec-g-skill-ripjaws-v-ddr4-2x8gb-3200mhz-cl15-f4-3200c15d-16gvr-868803/
https://www.morele.net/pamiec-g-skill-ripjaws-v-ddr4-2x8gb-3200mhz-cl15-f4-3200c15d-16gvk-852811/
https://www.morele.net/pamiec-g-skill-ripjaws-v-ddr4-2x8gb-3600mhz-cl17-f4-3600c17d-16gvk-831834/
https://www.morele.net/pamiec-g-skill-trident-z-ddr4-2x8gb-3600mhz-cl17-f4-3600c17d-16gtz-828910/
I think that 3600 all are still Samsung B regardless if CL is 16 or 17 but I don't know what exactly is in new batches.
list of what is probably Samsung B ... ~95%
https://www.morele.net/pamiec-g-skill-ripjaws-v-ddr4-2x8gb-3200mhz-cl14-f4-3200c14d-16gvk-858852/
https://www.morele.net/pamiec-g-skill-trident-z-ddr4-2x8gb-3200mhz-cl15-f4-3200c15d-16gtzkw-980792/
https://www.morele.net/pamiec-g-skill-trident-z-ddr4-2x8gb-3200mhz-cl15-f4-3200c15d-16gtzsw-972624/
https://www.morele.net/pamiec-g-skill-trident-z-ddr4-2x8gb-3200mhz-cl15-f4-3200c15d-16gtzky-1000360/
https://www.morele.net/pamiec-g-skill-trident-z-ddr4-2x8gb-3200mhz-cl15-f4-3200c15d-16gtzsk-972622/
https://www.morele.net/pamiec-g-skill-ripjaws-v-ddr4-2x8gb-3200mhz-cl14-f4-3200c14d-16gvr-860229/
https://www.morele.net/pamiec-g-ski...x8gb-3200mhz-cl14-f4-3200c14d-16gtzr-1118488/
https://www.morele.net/pamiec-g-skill-trident-z-ddr4-2x8gb-3600mhz-cl16-f4-3600c16d-16gtzsw-1022526/
these kits I have and are Samsung B
https://www.morele.net/pamiec-g-skill-trident-z-ddr4-2x8gb-3200mhz-cl14-f4-3200c14d-16gtzkw-980793/
https://www.morele.net/pamiec-g-skill-trident-z-ddr4-2x8gb-3600mhz-cl16-f4-3600c16d-16gtz-836224/
https://www.morele.net/pamiec-g-skill-trident-z-ddr4-2x8gb-3000mhz-cl14-f4-3000c14d-16gtz-860226/
also Supertalent 3600 and Ballistix 3466 which are not available in Polish stores
This is listed as Samsung B on mobo manufacturer's QVL lists:
https://www.morele.net/pamiec-kingston-predator-ddr4-2x8gb-3600mhz-cl17-hx436c17pb3k2-16-1378283/
there are many more kits, I just gave examples
regardless what kit you get, to make it work faster you have to play with timings ... if you don't want to or don't know how then higher frequency usually gives better results and optimal is 3600 CL16
