- Feb 18, 2002
When Windows 7 first came out, I think we talked about how "every time" you attach some USB flash drives, it prompts you to scan it and I think Vista does this too and I believe the conclusion was that this annoying feature cannot be disabled. (The flash drive doesn't need to be scanned every single time you attach the thing to your PC.)
Is it the old 'dirty bit' that is set there that triggers the mandatory scan prompt, did anyone figure out how to make Windows 7 stop asking for your flash drives to be scanned for errors?
EDIT: Three years later figured it out:
Start > Run > type:
msconfig
> OK > Services TAB > Click on Service to Alphabetize the display order > Scroll down and UNCHECK: Shell Hardware Detection [it disables Scan and Fix Flash Drive nag] > OK > Restart
Start > Run > type:
msconfig
