- Apr 28, 2008
- Melb, AUS
hi, i was checking Core Temp last night, and i saw that my TJ Max was set to 85.
i set it to 100, and noticed my temps were like 10 degrees warmer. this would then make my e6400 exceed 60 degrees under load which is kind of dangerous.
my current load temp is 51C and when i set the TJ Max to 100, load temp is 66C
after a closer look, i go into Core Temp > settings > TJ offset
and it's on 0 C. does this mean it's reading the temps correctly at TJ Max set at 85C, or does it need to be set at 100C?
can someone please help?
thanks a lot.
thanks a lot.
