- Jan 12, 2013
- Colorado Springs, CO, USA, Earth
Long story short, right now I'm unable to use an ethernet cable. I have a PCI WiFi card plugged into one of the PCI ports of the motherboard, but it's connection is so weak that it seems to lose connection every minute or so.
I want a new PCI WiFi card with a better connection, the one I currently have is apparently called the Realtek 8185, which is 802.11b/g. My main question is what numbers exactly determine the connection strength of a WiFi card? I don't know what the Mbps or whatever it's called this card has and what a "good" number is for it.
The router/modem thing is one floor below me, if that means anything. Also, does it help if the antenna of the card is facing the modem? One more thing, if there's multiple antennas on the card, what does that exactly help out with? Yes I know, I don't have the slightest clue with WiFi stuff.
