So I had the two new antennas installed into it (huh, they're much bigger than I expected them to be) for about 4 days or so, and though the connection is better than it used to be by a little bit, about once a day or so generally it will still disconnect. I'm still not quite sure what is going on here.
Also, I just noticed this now, I don't know how long it's been doing this, but my computer is emitting this static-like noise. I used LatencyMon to try and figure out what it was, and it says it could be caused by a WLAN card, and even when I disable it, it still makes the noise. I had this problem a long time ago, and the issue was that there was CPU throttling turned on in the BIOS, and by disabling that I fixed it, but now the problem is back and its NOT caused by the BIOS...
