What would you build if you needed a very small, FANLESS computer that has the ability to run windows 2000 somewhat fast and stable.
I was thinking about one of thouse Mini-ITX motherboards with a 150(?) watt sparkle power supply (with the fan removed) and a 4gb hard drive that supports HDD suspend mode. im not sure if you can remove the CPU fan from the C3.
it would rest in a small-as-possible sealed off plexi box with a few air holes in the top.
