- Jun 24, 2014
- DUBLIN/IRELAND
Hi there,
I need to find out what is the best coolant on the market and what makes it the best?
Hi there,
Exactly. No point in anything else.The best coolant is distilled water, with a kill coil. Any of the other coolants have a tendency to break down after a while, and gunk up your loop.
what would you reccomend me if I need a color coolant such a disitiled water?
Hi, it's with clear plexi window on right side which allows to take a look inside PC case adn it is not show rig.
as i said before I can use coloured tubing and I found Ice blue reservoirs for my self as well so far so good
I don't use kill coil due to esthetic purpose only that is why I was wondering myself if there is something else like liquid instead of kill coil.
Deadwater as stated already is the liquid forum instead of having a kill coil. I use both since my loop is fairly large. PTNuke isn't a bad idea either. Not sure if its been proven to run both at the same time without any issues.
Mayhems is supposedly one of the best on the market. If you do complete tear downs and clean the whole loop, you shouldn't have issues with it. Doing so every 6 months and replacing the fluid each time is likely the max you should let it go, you may need to do it sooner.If you have a rigorous schedule of maintenance, say a complete tear down and cleaning of the entire loop every six months, will fluids like Mayhem's Pastel line be acceptable?
