That's not a good idea. What happens when what's absorbing moisture is saturated? It'll drip, you don't want that in a computer.
Padding. Will. Do. Nothing. Once padding is wet on the outside you might as well just have water on the outside of your tubing. you need INSULATION. Something to prevent condensation from FORMING, not something to deal with it when it does form.
It can cool the water 12 C below room temperature without any condensation.
then to add paddings to that to be sure.
You will need to insulate in a way similar to if you were to cool your computer with DICE. There is plenty of documentation on this in the extreme cooling section. You will also need to insulate your tubing, I've never worked with that so I can offer you no assistance in that regard.
That depends entirely on the amount of humidity of any given day.
Ok neopads mentioned earlier are one way for insulation but going to research this.
You keep saying they absorb the water. You don't want absorption, if there's water to absorb, something has already gone wrong.
