Whats important, and what should each fan be focused towards..
So first thing i should look for in a fan is PVM compatiable correct?
Then next airflow or rpms? Does it matter how fast a fan spins or just how much CFM it creates?
I have a 240mm fan on side panel.. can replace that with 4 140mms
So if my 240mm pushes 100 CFM and i can buy 4 140mms pushing 80CFM
Is the Math 4x80 = 320 CFM between the 4 over the 100CFM of 1?
Ive got 2x140mm fans pushing on my radiator, and 1 240mm pulling on my radiator, should i match the RPMS/CFM on the push/pull setup for your radiator
