All the 2.80Cs I've tried did 3.3 gig at 1.45-1.525 volts, but they hit a wall fast from there. Basically, you needed to increase VCORE by 0.05, e.g., 1.55 to 1.60 to gain a 2 mhz more overclock. So they topped out around 3.45-3.5 gig at maybe 1.68+ volts. This is on air. All the ones I tried were either MO steps or Lxxxxx Malays.
They are crappy CPUs too; each CPU has a unique behavior. A few passed all 3D except the High Polygon test in 3DMark2001. I think two would pass all 3D except the CPU2 test in 3DMark2003, where I had to up VCORE to 1.75 from 1.68 to pass it.
If you run water you can gain maybe 5 mhz more on them.
