i'm a newbie, i have a 2.4 ghz intel processor, and i wish to buy an asus motherboard to it,
so my question,which motherboard will work great with my processor,
i heard that the 533 is good
what u think?
i'm searching for an asus motherboard, and i have a pentium 4 2.4 ghz intel,maybe it's northwind,
so which model of asus motherboards you advise me to buy,so it work good with it...
I don't know all the 2.4 flavours but mine both are hyperthreaded and support 800 FSB. If yours is the same and you want to overclock, then i suggest abit or asus ... my pref is abit for oc. Make sure the mobo supports both HT and 800 fsb is that is what your cpu runs.
I have only bought 2 new mobos .. the rest all came in used cpu/mobo deals.
Also, you will be looking for the right socket type - 478 for northwood, or lga775 (also called socket T) if it is prescott (not sure if there is a 2.4 prescott - i doubt it)
The intel site will help you with your processor id so start there.
