Ok, no prob. Im running two indepentent loops so as to not dump all the heat from the TEC onto the CPU.
CPU loop is a Swiftec 6002-775. Its the stepped base version which clears the ZIF socket with CPUs with no IHS. Pump is a MCP600 rebadged as an AquaXtreme. 160mm heatercore with homemade shroud and single 120mm fan. 1/2" barbs, and 1/2" hose.
GPU loop is a Swiftec MCW50-T upgraded to a 172w TEC powered by a Meanwell 24v PSU running at 18v. Pump is a ViaAqua 1300, running submerged with 1/2" fittings and 7/16" master clear. Also running a 160mm heatercore, but with a 330CFM 12v DC 172mm Fan.
Anything else? I know its not pretty, but its not supose to be, its supose to be easy to work on. I only happened across the CPU block working when I found out the Mach1 I was planning on using was dead.
