ATMIN im using my modded 4u server case its a case thats in desktop form factor i.e. not a sff case but then also not a tower case also if im not mistaken. The E8400 and other CPUs from that era had a common problem where the DTS (the Digital Thermal Sensor) would be unable to show temperatures below a certain point. This was referred to as having "stuck sensors". It was usually at some temperature somewhere around 40. Yours seems to have an inability to read any temperatures below 41. This is ok though because the DTS is only designed for accuracy at temps above 50. It doesn't mean 50 and above are perfectly accurate, but it means the temps get more and more accurate at 50 and above (as the temps get closer and closer to the TJ Max, which is 95 or 100 for the E8400, I forget which). If the temps were to somehow reach the TJ Max, the readings would be pretty much 100% accurate for safety reasons because the CPU's thermal safety would kick in. am i not correct there lastly
im using version 28.10 of prime95 and load temps while testing with prime were between 41c and 43c after 20 mins of testing
also im using arctic mx2 TIM and a corsair A70 cpu air cooler with 4 direct touch heat pipes in push pull config keep in mind my ambient room temp is 70 degrees F.
