- Sep 23, 2005
- saugerties ny
amd athlon xp 3200+ barton, asus a7n8x-e deluxe, kingston ddr400 khx3200ak2........................i have both 512 ram chips in the dual channel mode on mb, i have them set in bios at the advertised timing 2-3-2-6........cpu multiplier is locked at 11...........i cant get the fsb to run past 196 mhz without stability problems , games ctd , puter freezing up or restarting etc...........196 seems fine..............wanted to get your opinions on why you think this may be happening, i thought id at least get the 200mhz i should and then i could tweak the fsb up a little from there , but i cant even get the baseline.................ram is running 2.6v , cpu is 1.69...........i called kingston and of course they said they no longer support ddr 400 use in this board because of instability...............she said the highest they support is ddr 333.............wondering if theres some sort of a work around i could try or if im basically stuck with what i got , thanx oh , and the highest ive seen the temp is 48c using asus probe
