- Mar 12, 2002
Generally in normal automotive usage the coolant also acts as a lubricant on the water pump. The pumps we run in PCs are designed not to require additional lubrication.
@ATMNDIDE actually glycol raises the boiling temp of water also. Race cars as far as I know run straight water for the very slightly higher thermal performance. Since their engines are being pushed significantly harder they need every single W of transfer possible to maintain them.
Here are some graphs and a somewhat decent description of what PG/H2O mixtures boil and freeze at.
http://hellafunctional.com/?p=629
Copper Sulfate is a biocide but honestly its super mild. Its sufficient for your cooling loop and the worst thing that's going to happen if you spill it on yourself is mild skin irritation, and it needs to be pretty strong mixture for that to happen. Its perfectly safe to dispose of in any number of ways. Honestly there's probably more copper in my ground water than we add to our loops.
Pure silver is also a biocide, though it is subject to corrosion, but with fairly frequent coolant changes you can mitigate any clumping that may occur.
