Witch, use the tools I gave you, repeatedly in this thread, to figure that out...all you need is a temp probe to measure the AIR.
Basically, all you need to do is see what your current air intake temp on the rad is now, and figure out what your ambient is. Then, using the information I gave above (temp will rise and fall at 1:1 ratio) figure it out.
For example, if your intake air temp on the rad is 30C, and your ambient is 25C, then you should lose close to 5C off your temps if you can get that 25C air to the rad.
