I'm currently browsing for a new motherboard/cpu for my computer. I currently have a Gigabyte F2A78M-HD2 motherboard and am looking to get the Asus H81M Plus Motherboard HDMI 4K.
I'm curious as to whether this will fit in my current setup
Just had a look at the case and there's no ID / Serial Number etched into it, looking through past orders to try and find it. It's dimensions are 43cm long x 42 cm tall x 18 cm wide
Alright, I'm planning on changing with CPU along with it, (AMD A6-6400K APU) to (Intel Core I5 4460 3.2Ghz Quad Core) will that work? Or would I need to buy a new DDR?
Asus makes both AMD and Intel CPU compatible motherboards. An Intel 4460 CPU would need a socket 1150 motherboard. It's the socket that is the critical component in matching a CPU/APU with a motherboard. The motherboard needs to have the socket architecture to match the CPU.
The relevant information for the questions asked is in the post #1 and post #7. He's going from an AMD mATX mobo to an Intel mATX board-so it should fit in the same case. The new board he listed supports DDR3, same as the old board. The new (Asus) board model given in post #1 supports the chip given in post #7. I don't understand all the confusion?
