- Mar 16, 2012
If i upgrade from 32GB to 64GB will Windows 7 utilize all of that for caching my in use files and thus show improved performance?
I am video editing with large files
it is pro
You can go 64 then. I know I peg 16 from time to time and I have considered 24 but do you peg your 32? If not then it will do nothing for you.
Windows 7 architecture makes use of available RAM differently than say, Windows XP. Windows 7 releases RAM as needed.
Your bottleneck may be addressed differently, what are your system specs, do you have an SSD, which generation SSD is it?
3930k with gtx 680 4gb so my rig is about top of the line
ssd for main drive mushkin deluxe chronos 240gig
2x in raid 0 for the large video files
eventually when ssd price is down I'll get large SSD's and a mobo with sata3 to hose the files for edit but im not sure it matters more than the first import where it parses or converts the video files, after that they should be loaded in ram I'd think. $300 more ram is cheaper than $700 for 2x480GB ssd's which couldn't even house all my data
240GB SSD is now $138 after rebate:
http://frys-electronics-ads.com/ads/2012/09/14/58988/Corsair-240GB-
Are you working with a TB worth of data at any one single time? I store the finished product on mechanical HD but use SSDs for video project work.
I would post the question regarding how much of a performance increase would more RAM give you in the RAM section of the forums then come back here and post if it would give you more of a performance boost than SSD, which I think would help you moreso than extraordinarily large amount of RAM like that.
