I know what you wrote... that is why I asked if it was done (because what you posted alludes to that. ).
So you can change the .wav for the empty recycle bin, but changes won't take to the email notification? Is that an option in the sounds menu? I have never looked there since i had W10. can you post a screenshot of that window please?
I have to ask, is this Windows Mail, or Outlook? Either way, you will want to look for something in "options" about the notification. Not necessarily your audio profile in the Control Panel.
This is outlook. Email notification setup in Win10 is the same as 7. I also checked in the Win 10 notifications page and tried to disable popup notifications. In control panel I can choose wav. file, can test and it works. But when email arrives it is still default sound.
I have had users here at work with that issue. Granted, not many, but if you have both options checked, and it doesn't work, we haven't been able to find a fix. This however was with W7 and Office 2013.
