I have found a work around for this. It only makes a "copy of" if you drag-n-drop. If you copy/paste you get the screen asking if you want to replace the file. And this is with a Program file. I sure wish yu could go back if you wanted. Years of dragging will have to be relearned if you can't.This is not a bug with the OS after having a conversation with a member of MSDN staff this behaviour is normal. I did some test and this only happens with program and protected files.
You can copy pictures and other stuff and be prompt how to copy the file
Hope this helps
That's what I had found out. IF you want to copy and replace a file you have to use Copy/Paste. A little more clumsy but it gets the job done.Written by Ronnie Vernon
Default Drag and Drop in Windows 7 using the left mouse button.
In Windows 7 if you drag and drop a file from one folder to another folder, in the same location (for instance on the same hard drive) the file is moved, by default.
If you drag and drop a file from from one folder and drop it into another folder in a different location (for instance another hard drive, network location, CD, or memory stick) the file will be copied by default.
Default Cut or Copy and Paste in Windows 7.
If you right click and cut or copy a file, from any location, and then paste it to any other location, where a file with the same name exists, then you should see the popup with the 3 options to either Copy and Replace, Don't copy, or Copy but keep both files.
Default drag and drop using the right mouse button.
This is the same as previous versions of Windows. When you drop the file in the target location the context menu will pop up with the options to Copy or Move.
I"m hoping MS will bring back the old way. Really its not that bad, copy and paste works and its always a good Idea to have a copy of the file. I wote MS develoment team a letter asking if this could be changed to prompt the user to make a copy or replace choice. Maybe I'll just try to make this myself and submitt it for approvalThat's what I had found out. IF you want to copy and replace a file you have to use Copy/Paste. A little more clumsy but it gets the job done.
