Well, kind of disappointing. I have a feeling its either my ram and/or my mobo's pci/agp lock thats holding it back. 5 more mhz on the HTT and it starts crashing in games, and eventually windows. Overall the system performs better than my XP, though the XPdlt3c could reach up to 2.6ghz. Oh well.
Output from cpu-z.
CPU-Z version 1.27.2
CPUID Output
Number of CPUs 1
APIC ID 0
Name AMD Athlon 64 3000+
Code name Winchester
Specification AMD Athlon(tm) 64 Processor 3000+
Family/Model/Stepping FF0
Extended Family/Model F/1F
Brand ID 4
Package Socket 939
Core Stepping DH8-D0
Technology 0.09µ
Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, x86-64
Clock Speed 2299.7 MHz
Clock multiplier x9.0
HTT Bus Frequency 255.5 MHz
P-Rating 3000+
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2299.7 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 128 bits
Chipset
Northbridge VIA K8T800 Pro rev. 0
Southbridge VIA VT8237 rev. 0
Graphic Interface AGP
AGP Revision 3.0
AGP Transfert Rate 8x
AGP SBA supported, enabled
AGP Aperture 128 MBytes
Memory Type DDR
Memory Size 1024 MBytes
Memory Frequency 209.1 MHz (CPU/11)
CAS# 2.0
RAS# to CAS# 4
RAS# Precharge 4
Cycle Time (tRAS) 9
Bank Cycle Time (tRC) 11
DRAM Idle Timer 16
Memory SPD
DIMM #1
General
Memory type DDR-SDRAM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 512 MBytes
Max bandwidth PC3200 (200 MHz)
Part number CMX512-3200C2
Manufacturing date Week 00/Year 00
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 166 200
CAS# 2.5 3.0
RAS# to CAS# delay 4 4
RAS# Precharge 4 4
TRAS# 8 9
DIMM #2
General
Manufacturer (ID) Kingston (7F98000000000000)
Size 512 MBytes
Max bandwidth PC3500 (217 MHz)
Part number K
Serial number 07FFFFFF
Manufacturing date Week 19/Year 03
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 200 217
CAS# 2.0 2.5
RAS# to CAS# delay 3 4
RAS# Precharge 3 4
TRAS# 8 9
DMI
DMI BIOS
BIOS #1
vendor Phoenix Technologies, LTD
version 6.00 PG
date 01/19/2005
DMI System Information
System #1
manufacturer unknown
product unknown
version unknown
serial unknown
UUID 00000000-00000000-00000050-8DD145A9
DMI Baseboard
Baseboard #1
vendor http://www.abit.com.tw/
model AV8 (VIA K8T800P-8237)
revision 1.x
serial unknown
DMI System Enclosure
System enclosure #1
chassis type Desktop
chassis serial unknown
DMI Processor
CPU #1
manufacturer AMD
model AMD Athlon(tm) 64 Processor 3000+
clock speed 2304.0MHz
FSB speed 256.0MHz
multiplier 9.0x
DMI Memory Controller
Memory Controller #1
correction 64-bit ECC
Max module size 4096MBytes
DMI Memory Module
Memory Module #1
designation A0
size 512MBytes (double bank)
Memory Module #2
designation A1
Memory Module #3
designation A2
Memory Module #4
designation A3
DMI Port Connector
Port #1
designation PRIMARY IDE (internal)
connector On Board IDE
Port #2
designation SECONDARY IDE (internal)
Port #3
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
Port #4
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
Port #5
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
Port #6
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
connector PS/2
Port #7
designation PS/2 Mouse (internal)
port type Mouse Port
connector PS/2
connector PS/2
Port #8
designation USB0 (external)
port type USB
DMI Extension Slot
Slot #1
designation PCI0
type PCI
width 32 bits
populated no
Slot #2
designation PCI1
type PCI
width 32 bits
populated no
Slot #3
designation PCI2
type PCI
width 32 bits
populated no
Slot #4
designation PCI3
type PCI
width 32 bits
populated yes
Slot #5
designation PCI4
type PCI
width 32 bits
populated no
Slot #6
designation AGP
type AGP
width 32 bits
populated yes
DMI Physical Memory Array
Physical Memory Array #1
location Motherboard
usage System Memory
correction None
max capacity 16384MBytes
max# of devices 4
DMI Memory Device
Memory Device #1
designation A0
format DIMM
type unknown
size 512MBytes
Memory Device #2
designation A1
format DIMM
type unknown
size 512MBytes
Memory Device #3
designation A2
format DIMM
type unknown
Memory Device #4
designation A3
format DIMM
type unknown
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
Output from cpu-z.
CPUID Output
Number of CPUs 1
APIC ID 0
Brand ID 4
Package Socket 939
Technology 0.09µ
P-Rating 3000+
L2 Location On Chip
Chipset
AGP Revision 3.0
Memory Type DDR
CAS# 2.0
RAS# to CAS# 4
RAS# Precharge 4
Cycle Time (tRAS) 9
DRAM Idle Timer 16
Memory SPD
DIMM #1
General
Size 512 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
CAS# 2.5 3.0
RAS# Precharge 4 4
TRAS# 8 9
DIMM #2
General
Size 512 MBytes
Part number K
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
CAS# 2.0 2.5
RAS# Precharge 3 4
TRAS# 8 9
DMI
DMI BIOS
BIOS #1
version 6.00 PG
date 01/19/2005
System #1
product unknown
version unknown
serial unknown
DMI Baseboard
Baseboard #1
revision 1.x
serial unknown
System enclosure #1
DMI Processor
CPU #1
manufacturer AMD
FSB speed 256.0MHz
multiplier 9.0x
DMI Memory Module
Memory Module #1
designation A0
Memory Module #2
designation A1
Memory Module #3
designation A2
Memory Module #4
designation A3
DMI Port Connector
Port #1
Port #2
Port #3
Port #4
connector DB-9 male
Port #5
Port #6
connector PS/2
connector PS/2
Port #7
connector PS/2
connector PS/2
Port #8
port type USB
DMI Extension Slot
Slot #1
designation PCI0
type PCI
width 32 bits
populated no
Slot #2
designation PCI1
type PCI
width 32 bits
populated no
Slot #3
designation PCI2
type PCI
width 32 bits
populated no
Slot #4
designation PCI3
type PCI
width 32 bits
populated yes
Slot #5
designation PCI4
type PCI
width 32 bits
populated no
Slot #6
designation AGP
type AGP
width 32 bits
populated yes
usage System Memory
correction None
max# of devices 4
DMI Memory Device
Memory Device #1
designation A0
format DIMM
type unknown
size 512MBytes
Memory Device #2
designation A1
format DIMM
type unknown
size 512MBytes
Memory Device #3
designation A2
format DIMM
type unknown
Memory Device #4
designation A3
format DIMM
type unknown
Software
