- May 29, 2005
- Etters , PA
Has anyone removed the heatspreader (on top) of an A64 3000 or similar Winnie? I wondered if it is a crimp fit or thermal-epoxyied on. Even after re-seating, re-applying Artic Silver 5, and checking the faces of the speader, and HS with a dial indicator (pretty flat) I still think my temps seem a bit high. Usually around 40c idle /45c load at CPU, system is cool @ 26c/31c. Even cranking up the fan controller to" helicopter" setting doesn't help too much. I'd like to check the fit and thermal paste between the die, and spreader, but don't want to risk damaging the core. I remember when we had to lap the die to get it flat.
