- Oct 25, 2012
So, I finally wanted to give my m.2 SSD a try (since I've been running this new PC since I got it on the old installation from my previous build, the one in my sig)
I figured it would be a good time to upgrade to Windows 10.
So I bought a Pro licence for $40 and installed it.
Pros:
Pretty UI
Cortana
Better suport for newer technologies
Cons:
Discontinuity:
Two settings applications, a control panel, and buried menus, everywhere. Pretty obnoxious.
UAC.
It used to not be an issue. You'd turn it off right away in Windows 7 and that would be the end of it. However, I had spent about 3 days fighting with settings in two different locations before I finally discovered the hidden superadmin account "Administrator" which is basically Windows 7 with UAC off mode/Windows XP. It's unfortunate you cannot run the metro apps with it, but it seems a small price to pay.
I now know the issue is that the "Never Notify" setting in the UAC in windows 10 does not completely disable it like it did in Windows 7. This nanny-operating system that is increasingly prevalent is really getting on my and other superuser's nerves. Off means OFF, microsoft.
Tons of privacy settings:
Holy crap, there are a buttload. Typing, inking, browser data... It's a little ominous, daunting, and downright scary.
Game performance:
Some games in Windows 10 do not run the same as they do in Windows 7. Europa Universalis IV for one. No FPS drops in Windows 7, FPS drops in Windows 10.
Others, however, run the exact same (GTA V)
Updates:
Unable to stop updates/selectively install them.
I'm currently running with the Windows Update service disabled, perhaps that will curtail any unwanted updates (or any at all)
Overall, I give it about a 6.5/10.
Thoughts?
Pros:
Pretty UI
Cortana
Cons:
Discontinuity:
UAC.
Game performance:
Updates:
Thoughts?
