Thats probably why the update keeps failing because I updated the drivers from the website when I first build the computer. The other 2 updates that keep showing up are;
*Update for Microsoft .NET Framework 4 on XP, Server 2003, Vista, Windows 7, Server 2008, Server 2008 R2 for x64 (KB2600217)
Download size: 32.2 MB
This update addresses stability, reliability, and performance issues in Microsoft .NET Framework 4. After you install this item, you may have to restart your computer.
*Security Update for Microsoft .NET Framework 4 on XP, Server 2003, Vista, Windows 7, Server 2008, Server 2008 R2 for x64 (KB2656351)
Download size: 9.0 MB
Update type: Important
A security issue has been identified that could allow an unauthenticated remote attacker to compromise your system and gain control over it. You can help protect your system by installing this update from Microsoft.
BOTH of these updates install every time I try, but my system does not ask to restart, then when I check for updates again it's still trying to get me to install them..
