Classic Shell 4.0.6
[You can always use the option to go to Metro with SHIFT + Start Menu Button.]
Double click on Setup.exe to install the program.
UNCHECK: Classic Start Menu if you just wish to use the buttons + extras and not the Classic Start Menu for Windows 7.
or for Windows 8: UNCHECK: Classic IE9 if you want to keep new Internet Explorer settings.
Right click on Start Menu > Settings > Start Menu Style TAB > Classic with two columns >
Custom Button > Button Image has to be a single .bmp or .png image of three different buttons top, middle, and bottom button depicting normal, hot and pressed button style.
Special Items TAB >
Favorites: Display as a menu
User documents and User pictures: Don't display this item
CHECK: Show Log Off
UNCHECK: Show Help and Support
General Behavior TAB > UNCHECK: Check for Windows updates on shutdown
Skin TAB > Skin: Windows XP Luna
CHECK: Large Font
CHECK: Show User Picture
CHECK: Show User Name
Windows 8 Settings TAB > Disable active corners > All > OK
Start Button TAB > Custom Button > Button Image has to be a single .bmp or .png image of three different buttons top, middle, and bottom button depicting normal, hot and pressed button style.
If Classic Explorer Bar disappears, go to any folder > View > Click on down arrow under Options > CHECK: Classic Explorer Bar.
Right click on any Classic Explorer Bar icon to enter Settings > All Settings
[Backup drop-down menu allows you to save/restore settings]
To get the included Toolbar.png look, copy folder icons to C:\Program Files\Classic Shell\
Then Restore from the included Explorer Settings.xml file.
This is how it was set up:
SELECT: All settings > Navigation Pane TAB > CHECK: Don't fade buttons
Tree item spacing: 5 or 10 [Expand only folders that are needed on the left.]
Auto-navigate to the selected folder: Always
[Optional] Title Bar > CHECK: Disable breadcrumbs > to revert to old folder address bar display.
Toolbar Settings > CHECK: Big buttons
Large icon size: 32
CHECK: Same size buttons
Toolbar Buttons Tab >
SEPARATOR, Back, SEPARATOR, Forward, SEPARATOR, Up, SEPARATOR, Refresh, SEPARATOR, Copy, SEPARATOR, Paste, SEPARATOR, Cut, SEPARATOR, Delete, SEPARATOR, Undo, SEPARATOR, Custom Command, SEPARATOR, Properties, SEPARATOR, InvertSelection, SEPARATOR, SelectAll, SEPARATOR
Right click on Buttons > Edit Item > to be able to assign custom icons and button name labels.
Right click on empty space next to Folder Buttons to LOCK/UNLOCK the toolbars and be able to move them to the left.
Source of freeware icons was
http://www.glyfx.com/content/page/vista-common-toolbar-set-complete-edition.html
and
http://www.glyfx.com/content/page/xp-common-complete-edition.html
Starting with version 2.9.0, Classic Shell does not use ini files anymore. All settings are stored in the registry and editable through the Settings dialog.
This freeware
http://mythicsoft.com/agentransack/Page.aspx?page=download
offered clickable search parameters. It was installed to %SystemDrive%\Program Files\Agent Ransack\AgentRansack.exe and linked with a Custom Command button.
Version 3.6.8 is the last version compatible with Windows Vista
