I need to buy a wireless adapter for another pc. The asus adapters I found to be pretty good. The question here is; would the number of antennas affect the connection stability, speed and if so by how much. I'm not familiar with how antennas work and I don't want to blindly purchase the most expensive, most antennas one. So will they actually help, for something like gaming? The PC would be upstairs, and router downstairs under the room.
These are the ones I've looked at, not sure if spending the extra money will grant much benefit:
2 antennas: https://www.amazon.co.uk/ASUS-PCE-AC56-Carte-double-AC1300/dp/B00JNA337K
3 antennas: https://www.amazon.co.uk/ASUS-Generation-Dual-Band-Wireless-AC1900-High-Power/dp/B00EC9S3LI
4 antennas: https://www.scan.co.uk/products/asu...xoX_yw-PV2qdJ3CcQt8AgJYWJaZJSFcBoC1jwQAvD_BwE
Which one would you recommend for online gaming?
Edit:
I've also found this:
https://www.amazon.co.uk/TL-PA4020P...44&sr=8-1&keywords=internet+powerline+adapter
This is apparently said to have a more stable connection. I'm not sure though because the router is downstairs and maybe it won't work in the house, also the power line in that particular house could actually be worse than a pcie adapter. It also means an extra wire running across the floor because there's only 1 socket in the room - where the pc is across the room to.
Edit:
