- Dec 30, 2013
Hey all,
Been trolling here for awhile and now I'm seriously working on an OC on my tower just for fun.
I thought I had a good OC at 4.5 ghz using the AMD OD stability test (all changes are made in the bios, I was using this tool to monitor and test).
Then I decided to try out this prime 95 thing and it destroyed my OC. Temps shot up to 60 right away.
So, back to the drawing board. Original OC was only with multiplier and voltage (voltage wasn't that high, maybe 1.475 in bios). Now, I've lowered the multiplier and the voltage and upped the FSB to try to equal things out. 4.5ghz seemed to evade me so I'm shooting for 4.4ghz now.
Any tips for how to achieve this? I'm not sure what other voltages I may need to adjust?
Also, I've followed the other directions in the bulldozer guide to the T.
Last attempt was the following settings:
FSB-210
Multi-21
CPU Voltage-1.44
Cpu/NB V- 1.25
Other voltages are auto.
Temps got to 61ish in Prime95 within a couple minutes. What can I try to improve this OC?
FSB-210
Multi-21
CPU Voltage-1.44
Cpu/NB V- 1.25
