****Problem found and updated on post #5
I'm looking for feedback on my overclock for intense workloads.
System is a Hackintosh
8700k 1.335v 4.8ghz 0AVXoffset
Memory is overclocked to 3200mhz via xmp
Processor is delidded with liquid metal, kryonaut thermal paste on ihs, ek custom loop with supremacy block. Currently using a 240mm ek coolstream pe radiator with fans in push/pull.
I have removed and replaced the thermal paste/liquid metal multiple times to make sure it is applied properly and temps are always consistent.
Radiator is located at the top of the case with fans exhausting out.
The gpu is a gtx1080 that is also in the same loop, not overclocked.
Package power usage on the 8700k is 124w and the 1080 per Nvidia's website says 180w.
EK website lists the 240mm PE as able to cool 350w/10c @ 1800rpm (@ amb room temp of 25c) with it's Vardar fans in a push configuration.
Running full load cpu test (Mac yes test in terminal) with all cores/threads pegged and taxing the gpu via heaven at the same time, max temps are 82c on the cpu in the loop after temps stabilize.
If I added a second 240mm radiator, what kind of decrease could I see in temperature approximately and would it even be worth it as long as my temps while under full load are at 82c?
I've read many posts online stating the throttle temp for the 8700k is 100c. Is 82c still fairly safe for the system to run at for hours or possibly days with this load?
I am editing these numbers as I run Prime95 for stability/Torture Test small FFTs*
I am also open to any tips or suggestions that I might be overlooking.
Thanks in advance!
Thanks in advance!
