Would the 1.5V DLT3C overclock higher than the 1.6V DUT3C, why?
For Tbred B,
XP1700+ rated 1.5V is coded AXDA1700DLT3C
XP1700+ rated 1.6V is coded AXDA1700DUT3C
XP1800+ rated 1.5V is coded AXDA1800DLT3C
XP1800+ rated 1.6V is coded AXDA1800DUT3C
(For Tbred A, there are only 1.5V rated 1700+, 1800+. They have same code AXDA1700DLT3C and AXDA1800DLT3C also, so be careful. Have to use stepping code such as AIUHB, JIUHB and date to differentiate Tbred B from Tbred A.)
The L stands for rated voltage of 1.5V, the U stands for rated voltage of 1.6V, and K stands for rated voltage of 1.65V. There is no 1.65V rated Tbred XP1700+, XP1800+. The 1.65V is for TBRED B 2400+ and up.
They are based on 0.13 micron silicon technology, as the rest of the Tbred B siblings.
Acutally the lower voltage 1.5V Tbred B version, takes more current running at 1.5V compared to the DUT3C running at 1.6V !!! Both consume same rated power at their rated voltage.
E.g. from Tbred B datasheet, typical active current
1700+ @1.5V, Icc = 29.9A <--- DLT3C interesting, lower Vcore, higher current (or higher power/voltage)
1700+ @1.6V, Icc = 28.0A
1800+ @1.5V, Icc = 30.9A <--- DLT3C interesting, lower Vcore, higher current (or higher power/voltage)
1800+ @1.6V, Icc = 28.9A
This explains why the 1.5V Tbred B version can be overclocked to a frequency comparable to other XP, from 1700+ to 3000+ (and beyond, highest I heard is 3.1 GHz !!!), but at a lower voltage. This has something to do with the internal transistor characteristics, I suspect lower transistor threshold due to process variation. It remains to be seen whether it can be clocked at higher absolute clcok frequency (at higher voltage), compared to the 1.6V rated ones and the 1.65V bigger siblings, over a large sample.
Since it performs equally well at a lower starting voltage, it looks like it has the potential to become the top overclockers, provide that it can handle higher voltage without generating more heat per voltage due to leakage current, or no run away heat/voltage control problem.
Since the 1.5V can deliver similar clock performance at lower Vcore, there is a lesser need for a Vcore mod.
If you are running either a TB 1700+ or 1800+ with 1.5V or 1.6V rated ones, please post:
the highest clock frequency obtained, with Vcore, and if possible, stepping code, cooling means and loaded/unloaded die temperature.
For Tbred B,
