- Feb 14, 2003
I took a look at my father's PC (Duron 700) the other day and noticed that on boot it shows that the CPU fan is at 0 RPM and that the temperature is 92C (in the BIOS, w/o load!). He said it has been that way for months. He has also been complaining that his computer is really slow. Anyways, I decided to try to fix that. I took off the case and the fan was so clogged with dust it couldn't move. I took off the heat sink, which took a lot of force, because the green phase change material was burned and cracked. The rubber pads on the CPU had melted right off the chip and were permanently stuck to the heat sink.
I took an old athlon stock heat sink that I had and put it on with some silver thermal goo and the temperature dropped to 38C.
I find three things about this astounding.
1) The CPU could actually continue to work for that long at that temperature with no apparent damage.
2) There was no system instability, no locking up, not freezing.
3) Here's the one that really surprised me, as I've never heard it before. The speed of the CPU went up in benchmarks by about a factor of 3. Some tests (like 2D graphics) went up by a factor of 200.
I was unaware that heat could slow down a PC, I always thought it just caused instability.
MRD
MRD
